Bad Vibrations
Old Jan 28, 2008 | 11:58 AM
xzaq103's Avatar
FormerVendor
Default Bad Vibrations
Ok guys after checking fluids and bearings ad brakes I finally took my truck to the shop. They said it was the rear end the clutches have gone bad…. Apparently the limited slip disks have gone bad and are making the truck do that. Has this ever happened to you guys? I was under the impression that limited slip disks wore out over time but I did not know they could do this. The guy at the shop said he could fix it or put another axle under it. This is the tire guy I got to since I thought it was a front end issue I took it t him. After talking to him I called the guy my family goes to for transmission and rear end work he said its fairly common. I have about 6 options at this point. Here’s my question to you guys what should I do should I look for a Dana 80 or another 70 in good condition? Should I get mine fixed? (Dodge said 184.00 for the disks and 134 for both bearings) If I do get mine fixed should I put in new bearings (im trying to stay on the cheap) should I pull the limited slip and put in a locker? My last idea is my dad has a totaled 94 f250 with a sterling 10.25 I Might be able to use that but I imagine it would be a lot of work. And my last thought is to just keep driving it and try to ignore the vibrations is this a bad idea? Im stuck at what to do at this point guys. Thanks for any suggestions in advance.
Chris
Old Jan 28, 2008 | 12:03 PM
ndurbin's Avatar
Another option might be a used carrier from a junk yard. But then ya run into the problem I had, finding the shims and bearings at a decent price to set it back up right.
Old Jan 28, 2008 | 01:05 PM
Hammer's Avatar
http://www.car-part.com/
Here is a place for you to look if you decide to go the replacement route.
Old Jan 28, 2008 | 02:13 PM
xzaq103's Avatar
FormerVendor
thanks for the help guys. I think im just going to put new clutch packs in or maybe a locker.
Chris
Old Jan 28, 2008 | 07:10 PM
toy4xchris's Avatar
lockers are nice but if you do a lot of street driving or towing it could be more of a hassle. and personally I would do the bearings too that way you have many more happy hours of motoring without worries.
Old Jan 28, 2008 | 10:30 PM
94cummins12v's Avatar
the limeted slip is the best way to go for street driving and towing so just get it fixed the right way
Old Jan 19, 2012 | 09:30 AM
harry22's Avatar
What route did ya end up taking? My 96 is doing this. Im getting weird vibrations when i turn sharp or drive in a circle.
|WYG|SS
Jul 4, 2015 08:31 AM
Cumminsmoney
Mar 20, 2015 02:33 AM
Feb 5, 2015 12:10 AM
Mike H
Jan 25, 2015 10:08 AM
12vbomber
Nov 11, 2014 10:58 AM
