for those wanting to build hx35/40 hybrids
Old Jan 28, 2012 | 07:27 PM
93ford's Avatar
Default for those wanting to build hx35/40 hybrids
if you've been researching you've probably found the htt stage 3 compressor and wheel upgrade. puredieselpower has it for 315
I found this site today that has the following:
Compressor Housing for HX40 HX40W 61.00mm Bore Polished by BAE
Compressor Wheel for Holset HX40 Super 40 4035879 59.50mm Inducer - 86.00mm Exducer
i dont know the quality of their parts but they seem reputable. this gets you the desired, higher flowing 7 blade hx40 wheel and a polished housing for $100 less than the "stage 3" upgrade. i had a hard time finding this so I figured I'd help others who were looking to build a hybrid.
Old Jan 29, 2012 | 10:19 AM
12workinprogress's Avatar
Great find and thanks for passing it on for others to check out. Nice to seee a ford guy helping us dodge guys out .
Old Jan 29, 2012 | 11:05 AM
lodal cummins's Avatar
Anyone run this set up? What were the results or gains over the non hybrid like how much egts drop and what kind of spool up?
Old Feb 3, 2012 | 04:03 PM
94cummins12v's Avatar
i had one before my super 62 i loved it did great towing just not as big as i wanted at the time
Old Feb 5, 2012 | 10:54 AM
So is this upgrade really worth it without doing anything on the exhaust side? Really thinking about doing it as it fits my budget over a new turbo!
Old Feb 5, 2012 | 11:23 AM
Fox's Avatar
Fox
From everything I have heard the 6 blade is the highest volume wheel.....
Old Feb 5, 2012 | 11:28 AM
How many blade is the hx35 and this setup is a 7 blade
Old Feb 6, 2012 | 08:14 AM
93ford's Avatar
i've heard that people like the 6 blade because it has a loud whistle but that the 7 blade is the desirable wheel. that's why it's used for the super 40/35 hybrids and why it's a little more expensive. but they have the 6 blade and 8 blade wheels too.
Old Feb 6, 2012 | 08:58 AM
turbo2332's Avatar
its worth it if your budget is tight and your not interested in making a whole bunch of power. it will still be choky in higher rpms but will flow a bit more air down low. egts will go down but not significantly. its an improvement but not a big one.
Old Feb 7, 2012 | 05:57 PM
Well thats a bummer! I knew it was not going to be a big power maker but maybe its best to save for a new turbo, but crap they are spendy. But maybe i will do it right the put the hx35 on the 92
