Water temperature ?
Old Jan 28, 2012 | 03:34 PM
trentonwest29's Avatar
Default Water temperature ?
i had a cheap thermostat in my 94 cummins and the temp went up n down so i put a cummins thermostat in it now it goes to 150 degrees and stays there is this right?
Old Jan 28, 2012 | 03:42 PM
Heath's Avatar
Authorized Amsoil Dealer
That up and down was normal. Think it had to do with where it was located? Mine did he same. A steady 150 is pretty cool. Should be at least a 185-190 thermostat?
Old Jan 28, 2012 | 10:19 PM
Heavyhaul07's Avatar
My truck runs on the cooler side also some just do
Old Jan 28, 2012 | 11:41 PM
mikerumsey's Avatar
The up and down was deff normal all my cummins truck do that, and the 150 id say as long as you have good heat in the cab, leaves more room for heat if you were going to pull anything heavy..
RatsMC
May 4, 2015 05:25 PM
robbyS
Apr 16, 2015 02:22 PM
Oleoleson
Chevy/GMC Duramax 01-04 LB7
Mar 31, 2015 05:22 AM
Lawrence D. Sanders Sr
Dec 16, 2014 11:52 PM
yams
Dec 7, 2014 12:51 PM
