Manual trans swap
Old Jan 28, 2012 | 02:12 PM
flyingcrodeo's Avatar
Default Manual trans swap
I have a Get Rag 5 speed in my 92 but the syncronizers went out and need to rebuild it but i was wondering if a trans from a newer dodge would fit? Like up to an 05 or 06? What would be the best trans?? It's going to be used as a ranch truck to feed with and pull stock trailers and maybe move a tractor or small dozer around some, so what would be the best trans?? Like around the 1300 to 1500 price range cuz thats what its gonna cost to rebuild anyways. Any ideas??
It's a 4x4 by the way if that matters.
Last edited by flyingcrodeo; Jan 28, 2012 at 02:12 PM. Reason: Automerged Doublepost
Old Jan 28, 2012 | 04:24 PM
ricet07's Avatar
Pretty sure you can get a new trans to work, just need the adapter plate and starter from the donor truck, might also have to upgrade t case and driveshaft lengths. Just curious where you are getting 1300 to rebuild a getrag, you can pick up a new one for that. If it was just the synchros then they have a rebuild kit on ebay for $250 or check the sponsors sites might find some stuff in there. Now if you are hell bent on swapping the trans then I would go with the nv4500 5 speed out of a second gen 94-98.
Old Jan 28, 2012 | 05:09 PM
Well thats a complete rebuild all new everything and a 3 year warranty by a guy that is like a dodge guru and the sycronizeres went out and chipped some teeth tryin to shift so yeah couple gears are bad too and ok ill look into one
Beau_Jacques
Jun 26, 2015 12:17 PM
ReckONE
Diesel Engine Conversions
Feb 25, 2015 09:41 AM
Jgloveracob
Nov 16, 2014 07:27 AM
wisakowsky
Oct 14, 2014 08:13 PM
