Turbo ?s
Old Jan 28, 2012 | 09:23 AM
mudball_79's Avatar
Question Turbo ?s
ok, my 96 dodge auto 130k miles , the turbo recently went bad so i pulled one off of a later model,think bout 98 or so it was the same turbo just no waste gate control line hole tapped into the air side I pulled the exhaust housing off my old turbo to keep my exhaust flange. I am currently running with this line unhooked, in theory this should run the pressures higher,although not as controlled. My ? is as I have no gauges in yet so I am going by my "seat dyno/diagnostic" but it seems like my boost pressures didn't change or even lowered maybe.I very well could be looken up the wrong skirt, but on 98 n up engines are the turbos essentially the same as far as wastegates are concerned? And how does the X-hook work? Does it just hold more preload on the wastegate? If that is the case could my spring be weak on my wastegate cause it seems to pop off too easy as I am very close to stock setting,small grind on plate an slid foward,afc adjusted, nothing more. I can pull empty, up slight grade, from stop and go 1/4 throttle 3 seconds or so then let off and hear the turbo "stutter". Is this normal this close to stock, or should I check into my wastegate?
No boost gauge..........I know, I know........
Old Jan 30, 2012 | 05:04 PM
mudball_79's Avatar
nevermind.........injectors and gauges will be here this week, i'll figure it out.......
Old Jan 31, 2012 | 10:10 PM
turbo2332's Avatar
let us know what your readings are once you get your gauges hooked up. anything we tell you now would simply be a guess.
Old Feb 9, 2012 | 07:51 AM
mudball_79's Avatar
Default got boost
well, apparently the turbo/wastegate not an issue. Put my gauges in,all autometer with digital pyro, boost at wide open throttle is 32 to 35 psi so plenty of air, also put in some 60 hp injectors and tuned some more on the AFR ,seem to be getting plenty of fuel. I guess 3k gov springs and a lot of slushbox work next........
Old Feb 9, 2012 | 10:47 AM
turbo2332's Avatar
so is it working fine for you now? satisfied?
avatardvr
18
Aug 8, 2019 12:38 AM
n2brk
Feb 21, 2015 09:05 AM
jrsavoie
Feb 6, 2015 09:44 PM
tumble72
8
Nov 27, 2014 10:31 PM
GreenDieselF
Oct 20, 2014 02:05 PM
