throttle fluctuates up and down HELP PLEASE
Old Jan 27, 2012 | 07:04 PM
cumminsluke01's Avatar
Default throttle fluctuates up and down HELP PLEASE
while driving at around 2k the truck will back down out of the throttle even when the peddle is planted to the floor it wont throw any codes in the ecm or the trans.
Old Jan 27, 2012 | 07:11 PM
Castmaster23's Avatar
tps went out on mine n had to get a new one. idk if thats what ur havin trouble with but try resetin it by turnin the key without startin it. push the pedal to the floor n let it up slow then turn it off. run it n see what happens
Old Jan 27, 2012 | 07:38 PM
will anything happen when the computer is reset???
Old Jan 27, 2012 | 07:45 PM
no that just resets the throttle position sensor i think. you wont know anything has happened until u drive it. if it doesnt fix ur problem then its prolly not the tps
i dont know a whole lot about it but if ur tps is failing its sending incorrect readings to ur comp which makes ur throttle not right
Last edited by Castmaster23; Jan 27, 2012 at 07:45 PM. Reason: Automerged Doublepost
Old Jan 27, 2012 | 08:23 PM
empty wallet's Avatar
Torque management... what do you have done to the truck?
Old Jan 27, 2012 | 09:18 PM
holset cummins's Avatar
it sounds a lot like the tps sencer, i have found them at the best price for less than $200 on ebay.
Old Jan 28, 2012 | 07:19 AM
turbo20psi's Avatar
Old Jan 28, 2012 | 12:42 PM
zach2's Avatar
Cumminsluke01, I was having the same problem a while back. No codes, but dead pedal at times. It was my APPS. I bought a modified replacement from Tim at Timbom1976@aol.com. 717-577-1464. It included very detailed installation instructions with photos and Tim was helpful in diagnosing the problem over the phone before my order. This kit is the way Dodge should've done it from the factory.
Old Jan 28, 2012 | 03:44 PM
s&b intake 4in turbo back quadzilla adr and a airdog 150
