building with fuel economy
Old Jan 26, 2012 | 09:13 PM
staylorw250's Avatar
Default building for fuel economy
well im in the proccess of fixing my first gen im getting about 15 to 16 mpg now but i would like to see close to 18 to 20mpg the truck has the starwheel bottomed afc spring mia and a 31/2in straight pipe i have a bhaf ordered for it 727 trans and four wheel drive im just wanting this to mostly be a daily drive that isn't a fuelaholic any advice or experiences thanks
Old Jan 26, 2012 | 09:44 PM
white93's Avatar
The best setup I've run is
Tighter converter.
Stock fueling- Pump settings, injectors.
Better intake & exhaust.
Drive easy.
With that setup I could get 19-21 all day long with a 4wd 518 auto.
Old Jan 26, 2012 | 09:57 PM
so the stock convertor will yield bad fuel economy im hoping the bhaf will add a little bit
Old Jan 26, 2012 | 10:25 PM
ricet07's Avatar
Tighter converter.
Drive easy.
That extra gear helps though, mine has the 727 also and going down the hwy the old three speed turns some rpm's. A good converter will help a little and maybe a small gain with the bhaf. The afc spring MIA is not helping though. Turn the pump down a little and keep your foot out of it.
Old Jan 27, 2012 | 05:57 PM
yea i figured that spring wasn't helping see i figured the 727 trans would hurt since your engine is pratically rapping out going 50
Old Jan 30, 2012 | 11:16 AM
Edahall's Avatar
Here's my setup:
BHAF
HX35 12 cm Turbo
3.73 Gearing, 4x4, 3" lift
Timing advanced
Fuel turned up a little
NV5600 Transmission
Gear Vendors
2 cycle oil mixed with each fuel up.
At a steady 60-65 mph, I'm seeing 26 mpg average.
Old Jan 30, 2012 | 01:58 PM
12vChapa's Avatar
k&n filter, straight pipe, 68-69 mph. i can get 25mpg
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
Dec 5, 2014 03:10 PM
