fuel pump thread type
Old Jan 25, 2012 | 08:26 PM
94cummins12v's Avatar
Default fuel pump thread type
anyone know what size and type of threads the supply port on the mechanical lift pump is? 3/8 pipe threads into it but is loose
Old Jan 26, 2012 | 11:53 AM
Its Metric. 14mm for sure but I cant remember if its 1.25 or 1.5
www.vulcanperformance.com has whatever you need.
Old Jan 27, 2012 | 11:01 AM
i loocked at there selection but none had the description of lift pump inlet just the outlet if i remembor corectly the outlet going into the fuel heater is bigger than the inlet or is there outlet considered the fuel heater outlet?
Old Jan 30, 2012 | 02:16 PM
ok i did some looking i need the size of the fuel heater inlet
or my next thought is pypass the fuel heater completly since the in the ford its not even hooked up does anyone make a bypass strainer? i want to be able to strain the fuel similar to the heater?
scratch that i wasnt having this issue in the dodge so its ford related im gunna leave the fuel heater just for the strainer and hook mu 1/2 in line to the fuel heater line anyone know the size?
Last edited by 94cummins12v; Jan 30, 2012 at 02:16 PM. Reason: Automerged Doublepost
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
HardLuck
Jun 24, 2015 08:04 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:55 PM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
