Adjust Trans. Bands?
Old Jan 27, 2008 | 08:30 PM
survivor's Avatar
Default Adjust Trans. Bands?
Is it necessary to adjust the transmission bands?The books says to do it at 135,000 miles but the local transmission shop says it isn't necessary, What is your take on this?
Old Jan 27, 2008 | 08:33 PM
DazedandConfused's Avatar
Its best to leave them alone unless you want to run the risk of premature failure. You can do it but most trans shops say not to mess with them because they are easy to overtighten and burn the bands up.
Old Jan 27, 2008 | 09:18 PM
LOGANSTANFORTH's Avatar
i agree with Andy on this, when they go, they go, no real adjusting them......
Old Jan 27, 2008 | 09:36 PM
Begle1's Avatar
My transmission shifted really sloppy when I got it; I adjusted the bands and it cleared up.
Adjusting the bands also gives you a chance to check band wear; if they don't have enough material to be adjusted, chances are you're going to get some binding in the near future.
Old Jan 28, 2008 | 01:47 AM
94cummins12v's Avatar
ya if it aint broke dont fix it thats how stuff starts to go out is when you start screwing with it
Old Jan 28, 2008 | 07:59 AM
Cummins Express's Avatar
adjusting bands on a 727 trans is like changing the oil, after all our trans are just modified 727's. The front band is second gear, and is adjusted outside the trans. The rear band is reverse/low and adjusted just inside the pan. It's really not hard....torque down then turn back XX amount of turns. Loose bands lead to mushy shifts and heated contaminated fluid especially low and reverse that generally get worked harder. If you're not comfortable, take it to a shop, but just don't forget about them. Ignorance is not bliss
Old Jan 28, 2008 | 08:19 AM
GRI's Avatar
GRI
yeah I thought the bands were supposed top be adjusted at every service interval.
I adjusted mine on my 98. it isn't hard but you should do it with a torque wrench
Kfohne21
10
May 12, 2022 10:13 AM
Jake9473
Jul 22, 2018 08:19 AM
Rabbitjbu
Jul 28, 2015 06:03 PM
mtedrick4
Diesel Engine Conversions
Oct 13, 2014 09:25 PM
Pyrohigh
Oct 11, 2014 07:59 AM
