Dodge won't start
Old Jan 24, 2012 | 09:40 PM
morfitt55's Avatar
Default Dodge won't start
I have a 1994 Cummins and yesterday a went to start it and had to jump start it. After it started my lights inside and out got weaker and weaker until they didn't work. I turned the corner and my truck decided to die in the road. I had no power anywhere. I just replaced my batteries 3 weeks ago. I pulled the alternator today and had it checked. It tested good. If anyone has some input on what it is i would really appreciate it.
Old Jan 24, 2012 | 10:39 PM
lunk's Avatar
fuse able link maybe i know when i had an 89 ford gasser that happened and the alt was fine then i noticed a wire burnt in half and the parts guy told me that wire was a fusable link replaced it and everything went back to normal. i dont know if they still use those. check all wires coming of alt trace them to all the charging parts and check fuses. including battery cables if there corroded then they coul;d be corroded inhalf inside the rubber insulation
Old Jan 25, 2012 | 12:02 AM
morfitt55's Avatar
ok. thank you i will check that out
Old Jan 25, 2012 | 10:00 AM
South Tx Coal Roller's Avatar
Check your grid heater inside the intake horn. Sometimes they can short out and suck a lot of power fast.
Old Jan 25, 2012 | 11:04 AM
MillerBoyzDiesel's Avatar
check the crank sensor, if it goes out pcm wont see rpm signal and will not energize alt. to charge
Old Jan 25, 2012 | 04:59 PM
tiremann9669's Avatar
When you replaced the batteries are you sure you hooked all of the wires to the battery cables back up ?
Old Jan 26, 2012 | 03:00 PM
morfitt55's Avatar
Ya, I hooked the cables up properly
Old Jan 26, 2012 | 07:46 PM
cumminskid92's Avatar
Voltage regulator???...
Old Jan 26, 2012 | 10:54 PM
Heavyhaul07's Avatar
Best way to diagnose stuff start with the obvious And easiest
Old Jan 29, 2012 | 05:12 PM
TurkHunt128's Avatar
I am having similar problems, but my truck did not die...just no lights/voltage. I started at the alternator, wired in a external regulator and that fixed it for a week...no im guessing its the Crank Position Sensor....Try these hope it helps
Mac1997
Jul 13, 2015 05:08 AM
PeteBug
5.9L 24V Performance
May 23, 2015 01:17 PM
rschriek
Jan 26, 2015 07:30 AM
mtvivan
11
Jan 22, 2015 06:14 PM
elkmaniac
Oct 29, 2014 07:01 PM
