98.5 loosing power
Old Jan 24, 2012 | 09:31 PM
4mill95's Avatar
Default 98.5 loosing power
I have had my truck for about 3 months and i have noticed a loss of power.
I can be going up a hill and mash the pedal and not speed up at all. it just fills gutless on flat ground or a hill.
I have changed the fuel filter and air filter. it has 260k miles on it
could it be injectors/lift pump/ injection pump?
Any ideas?
Old Jan 24, 2012 | 09:37 PM
holset cummins's Avatar
it sound alot like the tps(throttle position sensor). the best deal is on ebay for less than $200 brand new and that is the cheapest i have found them
Old Jan 24, 2012 | 09:54 PM
turbo2332's Avatar
what are your fuel pressures idle and WOT?
Old Jan 25, 2012 | 06:31 AM
4mill95's Avatar
How can you test the TPS?
I will have to get a gauge what should they be?
Old Jan 25, 2012 | 06:45 AM
UglyTruck's Avatar
Does it sound like it is trying to go but just doesn't make the power? or does it blow lots of smoke when you mash the go pedal? if so check that you haven't ripped or blown loose an intercooler boot. It probably is the tps, but i would check the cheap stuff before spending $200 on parts. But i'm a cheap-
Old Jan 25, 2012 | 07:05 AM
4mill95's Avatar
it sounds good just no power. and no smoke at all. i will start checking stuff.
Old Jan 25, 2012 | 09:06 AM
turbo2332's Avatar
i bettcha your lift pump is worn out. prolyl about 0psi at wot, better look into it soon. if it is fuel pressure you can kill the vp44 pretty quick!
Old Jan 25, 2012 | 10:56 AM
dochawken's Avatar
Any ideas?
If it were the VP 44 there would be codes in your odometer window...check your lift pump at the injector inlet...if its 12 psi or so your in good shape. I had exactly the same problem 2 years ago and it was the ECM....If however it is the lift pump I recommend you replace it with a Raptor 100 or 150. Doc
Old Jan 26, 2012 | 06:59 AM
globalwarmingcontributor's Avatar
im going with throttle position sensor.. you can find them on Ebay or check this place out.
Diesel Auto Power- Good Service, Great Products, Excellent Prices!!! Willing to match/beat any legitimate price.
Old Jan 26, 2012 | 07:07 AM
4mill95's Avatar
I will check the fuel pressure this weekend. if its not that i will get the TPS.
