6.0 problem help!!
ok so i just got my 6.0 overhauled and it leak from the main seal took it back got it back and it still leaks, then i use the damn thing for like 3 days then i stop to put diesel and after i put diesel i try turnin it on and it wouldnt, then it turned on then off quickly, it would for a little with starting fluid then it would die, i then i pulled it home when i was almost home while i was getting pulled i popped it in gear then whala it turned on i drove it home and havnt tried turning it on no more. whats my problem with my truck?????
My friends 24v had a similar problem with the no start problem and we started it the same way. It only happened once. We never figured it out. We think the injectors or the pump hydralocked or cavatated
well it got a new block and low pressure pump egr deleted thats about it nothin thats not stock well see if it turns on tomorrow, oh when it died i checked the oil and it was low i put 10 quarts yea it was low remember it has a leak im takin it back tomorow i hope it turns on in the morning.
Maybe then again maybe not. Usually they stall before major damage but with any combustion engine the length of time operated low on or without oil is directly related to amount and type of damage.
Sent from my DROID BIONIC using Tapatalk
