boost question
Old Jan 24, 2012 | 09:17 AM
98cummins's Avatar
Default boost question
I am sure this has been asked before but I did not see it in the first 6 pages I scoured over. I recently upgraded my turbo from the lagmaster to a wastegated HX35 and I found on Ebay the adjustable elbow. My question is how much boost is safe with out major modding done. I have had the timing bumped and star wheel is bottomed out as well as fuel screw adjustment. I am adding a 3200 RPM spring and I know it already woke the truck up with the turbo but I am looking for a little more. Ideal goal is 200HP which isn't much but it will do for me as I want to keep it plenty reliable. I read that the turbo will handle up to 35 but I was thinking a number around 28? I just dont want to blow the head gasket or cause myself other problems. What do you guys recommend?
Old Jan 24, 2012 | 06:13 PM
timdale's Avatar
As long as it's under 40psi you won't need head studs and your h/g will be safe. With the mods you have your probably already close to 200hp. I don't think you'll boost much over 30psi right now, maybe a hair more once the spring is in
Old Jan 26, 2012 | 07:56 AM
98cummins's Avatar
According to the dyno run it was 165 at the rear tires before I put the HX35 on. You are correct though I don't know how much the turbo added.
Old Jan 26, 2012 | 03:39 PM
timdale's Avatar
Yeah, 165 at the wheels is close to 200 @ the flywheel, the turbo prob won't add much as the comp and turbine wheels are about the same, the hx just has a smaller exhst housing, but it does flow a little better
stewart.william.c
Feb 11, 2015 01:39 AM
ash23k
Dec 30, 2014 08:31 PM
Tsgbk9
Dec 23, 2014 11:54 AM
scottxmorris
Nov 11, 2014 03:28 PM
offroad00
24
Oct 23, 2014 03:28 PM
