pitman arm
Old Jan 23, 2012 | 06:52 PM
beardog78's Avatar
Default pitman arm
First of thanks to the guys who helped me on my tps situation. The truck is shifting perfectly.
I have a new problem. I'm trying to find a pitman arm for my truck. It's a 3500 4x4. They are no parts stores around here that can get one. Anyone know where i can get one? Do I have to go to a dealer for it? thanks.
Old Jan 23, 2012 | 06:53 PM
H.R.D's Avatar
http://www.moparpartsamerica.com/spl...?siteid=214583
Old Jan 24, 2012 | 09:30 AM
1AMatt's Avatar
Site Sponsor - 1aauto
Are you looking for a drop pitman arm for a lifted truck? The reason i ask is usually these dont need to be replaced because there isnt a ball joint in it
Old Jan 24, 2012 | 11:57 AM
beardog78's Avatar
No it is a stock truck.
Old Jan 26, 2012 | 09:01 AM
1AMatt's Avatar
Whats bad with the one on your truck??
Old Jan 26, 2012 | 11:50 AM
beardog78's Avatar
Well I think the ball joint on the arm is bad because there is a delayed reaction. When I turn the steering wheel with someone underneath the truck you can see that it hesitates. All the ball joints look good and so do the tie rod ends. It has very loose steering. I don't know what else it could be.
Old Jan 26, 2012 | 12:11 PM
harry22's Avatar
Pay close attention to the track bar too. Thats where my play was when i had to do mine. They have a hoin attatched the the driver side frame and a bushing on the axle end. I bought the Lukes link and bushing from vulcan diesel performance.
Luke's Link Tracking Bar Upgrade Dodge Ram
Old Jan 26, 2012 | 11:17 PM
Heavyhaul07's Avatar
Allso the steering box my be worn a little. Also some frame flex look into a steering box brace I I stalled one on my 98 helped out alot with similar symptoms
Old Jan 27, 2012 | 09:42 AM
1AMatt's Avatar
Bingo! If all your tie rods are good then your steering box is most likely toasted. The box brace is a great upgrade as well
tylerjp34
Sep 16, 2015 03:12 PM
Jmrobinson
Aug 20, 2015 07:56 PM
Walker.B
Chevy/GMC Duramax 01-04 LB7
11
Jun 17, 2015 10:40 PM
99dodge
Dec 15, 2014 04:56 PM
