performance upgrades..??
Old Jan 23, 2012 | 06:41 PM
crazycrawler32's Avatar
Default performance upgrades..??
i have a 98 12v looking to do a little upgrading... i have a (0) fuel plate and starwheel maxed.... i have a $1000 dollars to spend and want to do it wisely.... please any ideas... i use it to pull trailers and daily use.... the only concern i have with it is rite now when i tow mild loads or when im in the fuel alot the exhaust temp gets hot... thanks..
Old Jan 23, 2012 | 07:17 PM
adub12valve's Avatar
Transmission first! I effed myself on this one Do a search and find the free mods. plenty around there. And a bigger exhaust, if stalk, will help.
Old Jan 24, 2012 | 09:34 AM
1AMatt's Avatar
Site Sponsor - 1aauto
The transmission is a good place to start. If thats all set then you may want to invest in a good intake/exhaust. Then Id bump up your timing a little bit
Old Jan 24, 2012 | 04:15 PM
turbo2332's Avatar
exhaust, 4k's and buy the timing stuff so you can play with that.
Old Jan 25, 2012 | 01:08 AM
12v15004x4's Avatar
Doesn't maxing the starwheel require a lot of boost to move the arm which means it's restricting fuel??
Old Jan 25, 2012 | 09:49 AM
South Tx Coal Roller's Avatar
Upgrade the trans first. I know it's not as much fun as making more power but it's for sure a worthwhile investment. I would start with a good shift kit with billet servo and accumulator. I'm happy with the kit I got from DTT, I like it better than the Transgo kits. That will set you back around $370. After that I would suggest saving up a little more funds and picking up a billet triple disk converter. After doing a LOT of research I ended up going with a rebuilt triple from DPC (Diesel Performance Converters) and couldn't be happier. It's a night and day difference between a stock converter and a triple.
How high are your egt's getting?
duramaxtuner
LB7 Performance
9
Aug 5, 2015 11:36 PM
Jul 18, 2015 10:10 AM
Smith456
May 9, 2015 04:07 PM
duramaxtuner
04.5-05 LLY Performance
Dec 10, 2014 01:56 PM
Nov 3, 2014 01:40 PM
