head gasket
Old Jan 23, 2012 | 04:01 PM
cummins3500's Avatar
Default head gasket
So i took the head off of my 12v to do new head gasket and studs, but now I'm being told I was better off leaving the head on and replacing the studs cause now my head could have warped and when i put the new gasket n studs in ill blow my gasket out cause the head won't be clamped correctly to the block???? Is this true? And also can i get some info if any of u are running more then 50psi with stock gasket n Apr studs?? Herd u can
Old Jan 23, 2012 | 05:01 PM
gwhammy's Avatar
probably should get it trued since it's off. My head took a .015 cut to get it flat and still had a stain between three and four. Your this deep, probably would hate to lick it again for the 80 bucks or so it cost to get it cut.
I bought a different kind and don't have it running. What I've read if your head is true and torqued right they should easily. I'm running up to 55 on a stock 24 valve no studs and 327,000 miles.
Adam65
Jan 9, 2015 11:50 PM
Diesel Addict
Price Quote - Request A Price
Dec 10, 2014 06:52 PM
turbodiesel123
6.2L & 6.5L Performance
Nov 28, 2014 08:36 PM
HE22871
Nov 26, 2014 03:15 PM
1994cummims
9
Oct 15, 2014 11:37 AM
