Lessons learned...When this is off you should also replace...
Old Jan 22, 2012 | 09:50 PM
RamblinWreck's Avatar
Default Lessons learned...When this is off you should also replace...
I had my starter replaced. Then a month later the crank position sensor went out.
Lesson learned, if the starter goes out, this is about the same time the crank position sensor (CPA) may go out, so replace the CPS when the starter is off.
Post your lessons learned. When ___ is off replace/clean/adjust ____.
What should you have replaced when something else was off?
JHALL30
Chevy/GMC Duramax 01-04 LB7
Sep 8, 2015 07:00 PM
Aug 26, 2015 09:40 AM
D K
May 17, 2015 11:27 AM
ERK
Mar 4, 2015 01:04 AM
99RAMS
Tire, Wheel & Suspension
Jan 25, 2015 11:31 PM
