Injection pump problems
Old Jan 22, 2012 | 08:06 PM
cummins85's Avatar
Default Injection pump problems
Can anyone help me i have a 1993 cummins and i think the injection pump has a few problems, does anyone know why it feels like it pulls when im in drive and im stoped holding the brake in? i tried adjusting the fuel screw, idle, and smoke screw i was wondering if i have to turn the star wheel? an if i do i was wondering which way?
Old Jan 22, 2012 | 08:13 PM
ricet07's Avatar
Pull? like its idling high and wanting to go? Your idle should be around 700-800. Before you go too far making adjustments, you should write down what adjustments you have made so you can go back to that setting after all is said and done specially if you dont have gauges (pyro/boost). If its idling high and you backed the idle screw out all the way then turn your fuel screw out a little and the idle should drop.
Old Jan 22, 2012 | 09:30 PM
2500 hd's Avatar
did you adjust the fuel screw in or out?
Dbleo351
Nov 20, 2016 09:34 AM
Cummins86
Feb 11, 2016 05:24 AM
moneypitk5
Feb 12, 2015 11:01 AM
letters4and18
Dec 11, 2014 12:03 PM
rtbcoop
Nov 29, 2014 11:33 PM
