Door Rattle
Old Jan 22, 2012 | 02:26 PM
kieron_kohlmann's Avatar
Default Door Rattle
Does anyone else have problems with rattles in the door? Is there an easy way to fix this? It sound to me like the lock rod, but i could be wrong.
Old Jan 22, 2012 | 03:24 PM
tower_ofpower's Avatar
Good possibility the rods are loose, you can buy replacement clips from the "help" section. Either that or it may be you need new seals in your door, does your rattle tend to decrease with your window up?
Old Jan 22, 2012 | 04:21 PM
jdbigblue12v's Avatar
i have the same rattle was wondering if it is the rods if you replace them let me know if it helps
Old Jan 22, 2012 | 05:20 PM
Depending on where the window is, the noise is more or less. If you push in on the door panel it tends to go away.
Old Jan 22, 2012 | 05:49 PM
wildbill's Avatar
Sounds like your missing a few door panel clips.
Old Jan 22, 2012 | 05:57 PM
Sounds like you need some new weather stripping in the window channel plus rod clips.
Old Jan 22, 2012 | 07:31 PM
Where can i get new weatherstripping from? both doors and windows could use it. Do they make pre-cut ready to go?
Old Jan 22, 2012 | 07:55 PM
chromehound's Avatar
Another thing to check is the striker bolt for wear as it can make the door rattle if it's loose enough.
Old Jan 22, 2012 | 08:04 PM
ricet07's Avatar
I get my stuff through rockauto.com. They have the scraper seals, upper seal and window divider seals. It does sound like you might just be missing a couple clips though. Alot of times the plastic around the screw that it tucked under the arm rest cracks and lets the panel rattle.
RockAuto Parts Catalog
Old Jan 22, 2012 | 09:50 PM
big bad diesel 416's Avatar
Site Sponsor
yep rock auto makes some if there not worn or ripped just flat like mine were i put silicone in a syringe and went every 1/4in and injected it to plump it up it works slick
