Tranny Going Out
Old Jan 21, 2012 | 11:21 PM
98.12.valve's Avatar
Default Tranny Going Out
Well guys it seems that its finally happening, my tranny only has 80k miles on it since its been rebuilt and now its acting up, when it shifts the motor has to rev up like 500 rpms then it shifts and it shifts pretty hard, only time it doesnt do this is when it goes into 4th (overdrive) what do you guys think?
Old Jan 21, 2012 | 11:53 PM
ajlester's Avatar
check your throttle valve cable and the govenor pressure valve solenoid. you can probably get it scanned with a good scanner to check the pressures and for possible codes.
Old Jan 22, 2012 | 12:03 AM
tower_ofpower's Avatar
Fluid level, rev before application screams low fluid level. Either that or a sticky valve. Left over debris from failed/worn parts like to bind the valves up.
Old Jan 22, 2012 | 08:51 AM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
you might find a shop you can trust to check it out.
InheritedDiesel
Jun 3, 2015 09:39 PM
peterbilt
Chevy/GMC Duramax 06-07 LBZ
Apr 8, 2015 10:33 AM
wilki
Feb 12, 2015 09:04 AM
Ol' RED!
Dec 11, 2014 10:00 AM
Trevlar11
Nov 16, 2014 01:59 PM
