a little help here
Old Jan 21, 2012 | 03:59 PM
ebbtide357's Avatar
Default a little help here
ok this is what i got 1999 mbpr 4inch with muffler fass 95 fuel gauge amsoil bhaf waiting for delivery of edge ez and some more gauges my question is do i need a boost elbow or boost fooler? with the ez.i want to do more but for now this is my daily driver so this is it till the summer. im gonna do more with this truck down the road just waiting for some prices from goerand trans so i can build something to hold the hp. trannys fine just im sure when i start changing injectors and maybe bigger turbo and a bigger programmer i wont be able to keep my big foot out of it?
Old Jan 21, 2012 | 04:45 PM
globalwarmingcontributor's Avatar
personally i think you will be fine for now, until you throw some injectors in there. one option you can do is block the wastegate..it will add more boost. the stock turbo will be fine for now. this is just a cheap way to get more boost.. u can spend the 65 bucks or so to get yourt boost fooler if u want.. but i like saving money.
Old Jan 22, 2012 | 03:13 PM
holset cummins's Avatar
yea for now you should be fine. you will need a boost fooler once you get bigger injectors. just a little tip, i found that a set of 150 or 100 hp nozzles on that truck and the edge set to the lowest setting works great.
