Code P2284???
Old Jan 21, 2012 | 07:42 AM
2007 King Ranch's Avatar
Default Code P2284???
i have a 2007 Ford F 250 with a 6.0 diesel with 97k miles. The truck always ran fine. on december 31 i was driving down the road and it shut off. after some time
my local ford garage found it to be my HPOP, they replaced it along with the ipr, and oil cooler. when they put it back together it wouldnt run correctly with engine codes P2284, P2288. they said i needed a new fuel pump and my fuel pressure regulator needed a rebuild kit and it wont be covered under my 5 year 100k warranty so i took the truck back and replaced the fuel pump and did the rebuild kit myself and still not running correctly. the only code i have now is P2284 any help would be greatly appreciated. the truck starts hard and runs really rough until it gets some temperature then it runs better butn not right. when its at idle in park and i rev it up the engine seems to hold the rpm up for a second and then will come back down. it also has a knock after i let of the throttle!!
Old Jan 21, 2012 | 08:23 AM
brondondolon's Avatar
sounds like the icp but i could be wrong check it to see if there is any oil on or around it
Old Jan 21, 2012 | 08:40 AM
yeah thats one thing the code comes up with in the computer but it also comes up with Hp oil system leak. i was just wondering if other people have ran into this problem. TY for your reply
Old Jan 21, 2012 | 08:46 AM
03Powerstroke's Avatar
also test your FICM for piece of mind
Old Jan 21, 2012 | 09:01 AM
bkmac's Avatar
Did they cover the HPOP - mine went at 99,100 and was covered.
Interesting that it starts hard runs rough now - mine does the same thing and come to think that started after the dealer did the HPOP
Old Jan 21, 2012 | 09:04 AM
yeah that was all covered but not my fuel pump and regulator. I have zero confidence in my local ford dealer right now so that is why i turned to you guys.Bk what did you have to fix for yours to staighten out??
Old Jan 21, 2012 | 09:06 AM
TEST YOUR FICM
Old Jan 21, 2012 | 09:16 AM
bkmac's Avatar
I haven't - I am a newbie and that is why I am here. For right now I just plug it in and let it idle for a few and then buck down the road until it reaches temp.
I tested the FICM (easy to do - follow this link - https://www.dieselbombers.com/ford-p...procedure.html) and mine tested fine.
Will be trying some Rev X on next oil change. Currently I have 157,000 plus on the truck. Once I get some cash will be getting a good scanner to check codes and then start from there. My gut feeling tells me it is the glowplugs or the controller.
I have learned so much from the guys here it is amazing how willing they will help with your questions. Just make sure you give them the needed info ie truck year, mileage, trouble codes etc.
Old Jan 21, 2012 | 01:53 PM
i havent tested the FICM yet but im not getting white smoke im getting black smoke!!!!!
well just so everyone knows the ICP was the problem replaced it and all the problems are solved so far!!!And my FICM tested out at 48 across the board
Last edited by 2007 King Ranch; Jan 21, 2012 at 01:54 PM. Reason: Automerged Doublepost
Old Jan 21, 2012 | 01:54 PM
good, hows the starting???
