Turbo Problem?
Old Jan 21, 2012 | 02:43 AM
Maui J's Avatar
Default Turbo Problem?
I just bought a 98 dodge 24 valve diesel. I love it but have one concern. It seems only to be when its cold, I'll lay into it and it bogs, with lack of power. At first I thought it was the trany, and then I thought it was a fuel issue which it still may be, dout it but I noticed the turbo not running, I couldnt here it whistlin. The guy I bought it from went through a couple turbos and then this ones Brand New. Im sure because of what Im experiencing, But It seems like after a couple of miles of warm up it goes away. Pretty sure the turbos fine. Seems minor, Help Me Out!!!!!! Please Thanks
Old Jan 21, 2012 | 08:19 AM
diesel life's Avatar
Is your truck bone stock or does it have some mods???? If sonwhat are they. Do you have a fuel pressure guage????
Old Jan 21, 2012 | 11:39 AM
Maui J's Avatar
Default Stock
I'm fairly certain it is all stock. It would slowly and slugishly excelerate, but once it hits about 2300 RPM the turbo kicks in and takes off like there was never a problem
just replied, when you get a chance. Thanks
Old Jan 21, 2012 | 03:49 PM
luke46's Avatar
Probably not the same issue Mine kinda did this a while back turned out it was the map sensor giving a low boost signal but I had a code. It would throw me into kind of a "limp" mode till it saw more boost than it would spool up and take off. It was weird. Is your check engine light on or burnt out? Wait where are you from? Mine was a 98 24v that I sold to someone else.
Old Jan 21, 2012 | 05:52 PM
Maui J's Avatar
Default No real Turbo Spool
We just took it out and ofcourse when its cold only, it wouldn't spool. We are curious if it is a safety for the turbo so that it doesn't damage the turbo. or force cold air into the motor. I bought it in West Sacramento. Its super clean.
burndiesel
10
Feb 7, 2023 01:15 AM
avatardvr
18
Aug 8, 2019 12:38 AM
Hogridenfool
Nov 20, 2017 04:37 PM
n2brk
Feb 21, 2015 09:05 AM
GreenDieselF
Oct 20, 2014 02:05 PM
