V10- cummins swap
Old Jan 20, 2012 | 11:40 PM
Joshholtzclaw109's Avatar
Default V10- cummins swap
I have a 01 dodge with the v10 and I fixing to put the 5.9 24v cummins in it. it is automatic and I need to know all the partthat has to be change
Old Jan 20, 2012 | 11:49 PM
RanchhandTCR's Avatar
Harnesses, motor mounts, bell housing, what kind of transmission the 4RE?? Im not 1000 percent sure what dodge ran with the v10. Were going to do that with a friend of mine V10 one day but till then hes got a 6.7L Cummins to drive.
Old Jan 21, 2012 | 12:36 AM
dieseldude848's Avatar
it should have a 47re, and bell housings are the same
Old Jan 21, 2012 | 09:33 AM
Do I have to do any tranny work
It has the 47 re do I have to change the fuel pump
Last edited by Joshholtzclaw109; Jan 21, 2012 at 09:33 AM. Reason: Automerged Doublepost
Old Jan 21, 2012 | 11:38 AM
01quadcab's Avatar
there will be some trans work needing done as something inside is different and I can't remember what. yes you will need a different fuel pump and have to remove the intank gas pump and put a draw straw in and a good fass fuel system on and have no fuel issues
Old Jan 21, 2012 | 05:42 PM
whats the best fuel system to put on it i want to have 450 to 500 hp when its done and i dont wat to have to worry about fuel problems so all i need is motor mounts wiring harness and do trany work does anyone know if the computer comes with the harness is there anything else that i need to get
Old Jan 21, 2012 | 10:16 PM
Fass are good pumps you gonna want 150 gph or more, I redo alot of things wile you have the engine outta the truck. New injectors have a worthy injection pump a stock VP44 will not live if you want 400-500 HP outta it. Nor will a stock P-Pump.
Old Jan 22, 2012 | 01:02 AM
01quadcab's Avatar
wow I disagree as my stock so vp44 went 683hp and is still working today made over 500hp last 3 years. over 200k on the truck. a fass 95 will supply all the fuel you need for 600hp. just take everything you can get from the donor vehicle when doing the swap. I can't think of all the little things right now but never hurts to have extra.
DieselDan370
Diesel Engine Conversions
Aug 23, 2016 02:24 PM
savage-rider
Sep 26, 2015 12:43 PM
STDiesel59
Jul 11, 2015 10:09 AM
DieselDan370
Jun 8, 2015 06:21 PM
mcclusk
Feb 21, 2015 09:50 PM
