The seventh gauge
Old Jan 20, 2012 | 12:53 PM
moparbubbabt59l's Avatar
Default The seventh gauge
Im trying to decided what I should put for my 7th gauge
1. Optix boost
2. Optix pyro
3. Optix trans temp
4. Isspro tach
5. Mopar oil pressure
6. Auto meter fuel pressure
7. ?
Do I do a drive pressure a real coolant temp or something else?
Sent from my DROIDX
Old Jan 20, 2012 | 05:05 PM
mechanically's Avatar
A Vacuum gauge would be cool. Basically a motor monitor. Can also help your fuel economy.
Old Jan 20, 2012 | 06:01 PM
1st_gen_puller's Avatar
If you do any towing a rear end temp gauge would be cool...
Old Jan 20, 2012 | 10:25 PM
big bad diesel 416's Avatar
Site Sponsor
I run these
pyro
boost
oil psi
oil temp
fuel psi
coolant temp
rear diff temp
front diff temp
trans temp
tach
Red ones on the pillar pod
blue in the spot that said "Cummins and wait to start and all that"
green in a 2 gauge dash pod turned upside down from an shelf above the rear view
and the last 2 on the dash
i am soon going to build a dash and move most of them there
going to add exhaust back psi when i built the dash
where would you put it?
Last edited by big bad diesel 416; Jan 20, 2012 at 10:25 PM. Reason: Automerged Doublepost
Old Jan 21, 2012 | 08:29 AM
Sent from my DROIDX
Old Jan 21, 2012 | 09:55 AM
A lot of guys run a post turbo pyro. I don't really know why you would, but I know ISSPRO makes color coded pre and post turbo pyros.
Steve123
Sep 28, 2015 02:36 PM
Powerstroke36
Sep 21, 2015 08:32 PM
MrCat4974
Mar 23, 2015 11:30 PM
99stackedpowerstroke
Feb 7, 2015 10:58 AM
scottxmorris
Oct 8, 2014 02:14 PM
