oil/coolant leak
Old Jan 20, 2012 | 08:58 AM
Oliver Green's Avatar
Default oil/coolant leak
Ok I dont know what's going on really and I'm hoping that someone does
So I was running smarty and I wanted a monitor instead so I put a edge juice w attitude cts in and test drive it and got back and it smelt like burning out so I shut it off and popped the hood to find oil everywhere and I looked on the ground and I had oil coming out the front somewhere and coolant out the back so I sprayed it all off with ether and found the oil was coming from between the block and the head and haven't really looked for the coolant yet so immediately I thought head gasket but is there oil pressure going to the head in the front in a 24V cause I have been told that there was no pressure there so I didn't know if that was a possibility
Please let me know if you would have an idea of what this could be
thanks to all
Old Jan 20, 2012 | 10:07 AM
J-Pipes's Avatar
Did you still have the smarty loaded while trying the edge, if so, what setting were you on, if you had it adding timeing then my guess would be too much cylinder pressure, blown head-gasket, but I'm no engine guru, just a guess.
Sent from my PG86100 using Tapatalk
Old Jan 20, 2012 | 10:14 AM
MillerBoyzDiesel's Avatar
the rocker arms get fed oil through passages in block that comes up through head gasket and head. sounds like you popped the headgasket.
Old Jan 20, 2012 | 11:15 AM
GuyWithA24Valve's Avatar
sounds like a head gasket
Old Jan 23, 2012 | 05:26 PM
I did take my smarty off before i hooked up the edge but thank you everyone that is what i was thinking and I have it in the shop now and am taking the head off the change the head gasket, while I am doing that any recommendations on head gaskets for holding up to 60 lbs of boost with head studs
Old Jan 24, 2012 | 07:44 AM
you could always fire ring or o-ring for reassurance. Id look into getting a set of stiffer valve springs too if you dont already have them.
Old Jan 25, 2012 | 05:25 PM
Yea that was the next thing that I was thinking about doing since I have to take the head off
Old Jan 25, 2012 | 09:12 PM
Smarty=Cummins's Avatar
Now if you just put new head studs in with a stock head gasket wat kind of boost can you handle then.
Old Jan 26, 2012 | 08:38 AM
I put a new gasket on at the same time but I was running about 50 to 53
Old Jan 26, 2012 | 12:22 PM
01quadcab's Avatar
while it's off save yourself the trouble of having to do it again and o-ring it and stud it and be done. I did this and it's held 85psi for 2 years racing everything chance I got. The cost to do it now it's less than doing something again later. also use a factory head gasket
LariatOutlawGirl
Sep 1, 2015 02:17 AM
IHdude
Chevy/GMC Duramax 01-04 LB7
Jul 12, 2015 11:14 PM
InheritedDiesel
Jun 3, 2015 09:39 PM
ash23k
Dec 30, 2014 08:31 PM
Dec 5, 2014 08:30 AM
