5th gear back off
Old Jan 19, 2012 | 08:21 PM
01_cummins's Avatar
Default 5th gear back off
so i just bought a 2001 1 ton dually with a five spd and injector pump and turbo off a HO with head studs exhuast clutch and injectors of some kind not sure what yet and was on my way to work today and went to go into fifth and it wasn't there and when i finally got it it felt like it was barely there and it wouldn't accelerate just kept slowing down...i didn't want to buy a 5 spd becuase i know they have this problem and now it bit me in the a@@ im wanting to see if there is anybody that knows if i need the ecm off a 6 spd or if i can just put the 6 spd in and also r the t-case's the same? also i know there are kits somewere that you can fix the problem permanantly? and will it hurt to drive around with just 1-4? if anybody can answer any of the questions above id really apreciate it. thanks
Old Jan 19, 2012 | 09:04 PM
01quadcab's Avatar
do you have a 6spd? the output size is different on the 6spd if I remember correctly. I have known a few people who drove around a couple days before they could get the trans fixed and had no added issues.
Old Jan 19, 2012 | 10:44 PM
puffsmokeonya's Avatar
just get a new nut. they are easy to change. fix it once never have that problem again
Old Jan 20, 2012 | 08:16 AM
MillerBoyzDiesel's Avatar
to change to 6spd youll have to get altered driveshafts, or find a set off of a 6spd truck and change your clutch disk unless your 4500 already has the larger input shaft. the 4x4 shift linkage is adjustable. Youll need a 6spd trans mount bracket but Im pretty sure you can reuse the trans mount itself. Ecm dont matter and if I remember right you dont have to lengthen the harness or vaccum lines. Not a too bad of swap. On the other hand WIT transmissions has a very good updated 5th gear nut. A more permanant fix is a Torque king mainshaft but, its not cheap. You might have just stripped the lugs off of the 5th gear synchro hub, thats a pretty cheap fix.
Old Jan 20, 2012 | 03:52 PM
01_cummins's Avatar
i have already got the larger input shaft and 13 inch dual disk im overpowering the transmission and hauling to heavy for the 4500 is the main issue so i don't think the nut will be a permenant fix for me does anybody know anyone that sells a built five speed? i don't have 3000+ for a six speed or the drive shafts out of one either
Old Jan 20, 2012 | 04:02 PM
Did you look at the torque king mainshaft? We can build you one here fully cryo treated with the torque king mainshaft. QUAD 4 x4 LLP Your 4x4 Experts <---- link to torque king mainshaft
Old Jan 20, 2012 | 08:30 PM
01_cummins's Avatar
yeah i actually read your page a few days back. what does it run? and im not sure if fifth is my only problem anymore because i went to park and lost 1-4 and could barely squeak it into revearse then once i had backed around to park i had first again
Old Jan 21, 2012 | 06:57 PM
Well its not my page but, we buy from them and that shaft has never given any trouble to date, I wana say its around 900 but dont quote me on that. You mean you couldnt get trans into a gear at all? That could be just the dual disc. If you have a upgraded clutch master/slave unit try to adjust the push rod at the clutch pedal under the dash. South bends are adjustable and sometimes you have to play with them to get a good setting.
Old Jan 22, 2012 | 10:50 PM
could be the four bolts that bolt your shifter down. ive seen that ALOT pull out the stuff around your shifter and check those bolts
Old Jan 22, 2012 | 11:07 PM
01_cummins's Avatar
how will i acces them thru the cab or around from below??
Jun 4, 2015 09:30 PM
Apr 3, 2015 11:50 AM
miked2805
Oct 29, 2014 06:20 PM
Oct 18, 2014 10:52 AM
Spiderman
Oct 6, 2014 09:52 AM
