1st gen questions
Old Jan 18, 2012 | 09:22 PM
staylorw250's Avatar
Default 1st gen questions
my truck was in a front end collisions and i have some questions
1. my brake pedal doesn't spring back all the way resulting in the brake light staying on
2. my wait to start light flashes after the truck is running
3. the driver side of the axle slide back on the leaf spring i know i need new u bolts but is there a pin dowel or bolts that sticks through the middle to keep the axle from sliding
Old Jan 18, 2012 | 09:26 PM
lunk's Avatar
there is a bolt for the leaf pack to keep the axle centered and pack together
Old Jan 18, 2012 | 10:42 PM
ricet07's Avatar
Your pedal could be going back all of the way but the brake light sensor might need to be adjusted. There should be a pin to keep the axle centered.
Old Jan 18, 2012 | 10:47 PM
ok i didnt know you adjust that switch
Old Jan 19, 2012 | 08:45 AM
ricet07's Avatar
It should be threaded somewhat or grooved to where you can adjust it out and in. I had to do mine awhile back.Let me know if that works.
As far as the wait to start light flashing, it could be that your grid heater is trying to cycle after the truck is running. Not too sure on that one all of my panel lights have never worked.
Old Jan 19, 2012 | 11:02 AM
tower_ofpower's Avatar
Flashing for a fault, only time I've had mine flash is when my intake temp sensor is unplugged, may have a faulty intake sensor.
Old Jan 19, 2012 | 08:44 PM
that may be the truck got pretty banged up and ok ill tell you if that fixs it
Old Jan 20, 2012 | 11:26 PM
well i adjusted that switch and that fixed the brake light problem
Old Jan 21, 2012 | 11:41 AM
ricet07's Avatar
Good deal and good luck with the other problems.
Old Jan 21, 2012 | 12:52 PM
NadirPoint's Avatar
You should take a real good look at the spring leaves themselves for cracks or even broken leaves. That is a pretty typical result after that stuff starts coming apart.
Cdog121
Nov 16, 2015 01:49 PM
klaveric
Oct 20, 2015 07:17 PM
Tory4
For Sale
Feb 1, 2015 08:33 PM
ajpt6.9
Dec 4, 2014 12:06 PM
myago92
Oct 17, 2014 08:50 AM
