TRANS Not responding
Old Jan 18, 2012 | 07:03 PM
rncummins's Avatar
Default TRANS Not responding
HELLo ALL I'm a noob so any info will be greatly appriciated. My truck is a 2003 cummins 2500 4x4 the PROBLEM I'm having is when i shift into gear the trans goes in gear but the indicator is not showing anything (the circle around the gear its in) it does appear in P and N but not in R D321 but it does go in gear and the trans will not shift .What I have done to fix it so far is change fluid ,filter ,govenor pressure sensor and silenoid ,range selector switch on the trans and PCM . Is there any sepperate comp for the trans? THX in advance for any help!!!!!!!!!!!!
Old Jan 21, 2012 | 09:37 PM
Klickster102's Avatar
my 06 did that only it wouldnt do it for the park light up, worked in all other gears, i had to adjust the shift linkage, you could try that...
Old Jan 22, 2012 | 07:34 PM
rncummins's Avatar
thx klickster I will check in to it .
Jake9473
Jul 22, 2018 08:19 AM
Rabbitjbu
Jul 28, 2015 06:03 PM
wisakowsky
Diesel Engine Conversions
Oct 14, 2014 08:13 PM
pv89sj
Oct 12, 2014 02:45 PM
Pyrohigh
Oct 11, 2014 07:59 AM
