throttle cable snapped on way to work
Old Jan 18, 2012 | 06:28 PM
ebbtide357's Avatar
Default throttle cable snapped on way to work
looked all over had to order from stealership. its cold up here looking for any shortcuts to replace because im going to be outside doing this any info how does this unhook from the pedal and the apps? trying to keep warm little help please.
Old Jan 19, 2012 | 06:47 AM
chadcycle 2500's Avatar
Basicly it pulls off from tps,i think I used two pry bars one on each side of the cable end at the post that sticks out of the trottle arm, move one prybar toward the engine one toward the left fender it should pop off. The outer cable has two tabs that snap into the firewall just behind the accelerator pedal. Small pliers may help here.Squeeze& push through towards engine. The cable just unclips off pedal arm,wriggle& pull. Hope this helps!
Old Jan 19, 2012 | 07:10 AM
J-Pipes's Avatar
Use a half inch wrench to hold the clips in against the firewall, not much room in there, fought with mine for a long time before I I figured that out, and make sure u get the old gasket
off or it won't clip in with the new one.
Sent from my PG86100 using Tapatalk
Colbyflory
Aug 16, 2021 09:19 AM
Blair@BD
BD-Power
Sep 10, 2015 12:29 PM
bonestock
Feb 1, 2015 08:41 PM
1stgenswap
Nov 3, 2014 09:45 PM
Oct 18, 2014 10:10 AM
