01 2500 still not starting
Old Jan 18, 2012 | 06:25 PM
gfmccutc77's Avatar
Default 01 2500 still not starting
My 01 2500 5.9l cummins was having a hard time starting, and one morning I went out and it hasn't started since. I have since replaced the fuel lift pump, fuel filter, and injector pump. I bleed filter housing, then the injector lines. Thing still won't start and is not throughing any codes at all. Does anyone have any suggestions????
Old Jan 19, 2012 | 03:14 AM
ajlester's Avatar
there is a pressure port on the injection pump also. bleed the filter port, then the injection pump port, then crack open #3 and #5 injectors. if that doesnt work check the fuel system relay under the hood in the fuse box. u can swap it out with the horn relay. good luck.
Daniel Finney
Oct 22, 2019 01:58 PM
hurriedcoyte
Jun 19, 2015 06:26 AM
DirtyDiesel58
Jun 7, 2015 11:50 PM
InheritedDiesel
Apr 12, 2015 04:35 AM
Dec 29, 2014 10:20 AM
