Alternator Wiring
Old Jan 26, 2008 | 09:45 PM
sawmillman's Avatar
Default Alternator Wiring
I'm looking to wire in a external voltage regulator mine went poof.does anybody have a diagram to go by I am thinking of using a fender mount from a older model dodge.
Old Jan 26, 2008 | 10:11 PM
DazedandConfused's Avatar
Isnt all that controlled through the PCM? I'll try an get on alldata tomorrow for you and see if I can find anything.
Old Jan 26, 2008 | 10:18 PM
Hammer's Avatar
How about this deal instead of all the tapping into stuff......
http://www.fixinrams.com/id12.html
Old Jan 27, 2008 | 04:57 PM
Cummins Express's Avatar
Our alternators have two field studs on them, and are insulated therefor polarity doesn't matter. Just unhook the two small terminals on the back and leave the power and ground. ANY regulator will work. If it has only one field wire, find out if it is an "A" circuit or "B" circuit field, another words, does it provide positive or negative field? Whichever the case may be, hook it to one stud on the back of the alternator, and either ground, or hook to positive, the other stud. If your regulator provides both field wires, just hook them up...polarity don't matter. Presto, you're charging.
Old Jan 28, 2008 | 01:07 AM
94cummins12v's Avatar
if you need the wireing diagram go to napa or autozone and buy a haynes rebuild book for your truck it has all the wiring scematics in the book
