Turbo oil drain tube size??
Old Jan 17, 2012 | 04:53 PM
RamblinWreck's Avatar
Default Turbo oil drain tube size??
The rubber tube coming from the turbo oil drain is leaking, I tried tightening the hose clamp and no help. Is this a Dodge only part or can I use oil/gas rated tubing? If so what size is it? 1/2" ID?
Old Jan 17, 2012 | 07:16 PM
thebullet83's Avatar
it's closer to 3/4" id.
Old Jan 21, 2012 | 03:52 PM
I measured the steel tube that the rubber hose mounts to at 7/8", so the rubber hose is 7/8" ID. Found some hose at a local rubber and gasket shop. It is Novaflex 841, marine exhaust hose rated for oil use and max temp of 210F. It was about $7/ft, I got 2' if anyone needs some, PM me. The piece that was on there was 3", I replaced it with a piece that was 4" long. Seems to fit fine.
Old Jun 30, 2012 | 09:21 PM
bkstraub8's Avatar
hey there, i have called every shop in new york and i cant find this hose! do you still have some? please text me if so 509 389 0825 thanks! brandon
avatardvr
18
Aug 8, 2019 12:38 AM
honda89
Oct 17, 2015 01:08 PM
|WYG|SS
Aug 19, 2015 10:53 AM
rodbuilder
Jun 26, 2015 12:48 AM
MrCat4974
Mar 25, 2015 08:13 PM
