94 cummins fueling question.
Old Jan 17, 2012 | 12:42 PM
Mattman347's Avatar
Default 94 cummins fueling question.
First off, hello! I am new to the 12valve but not new to diesels. I work for full force diesel and we do mainly powerstrokes. I have been doing a lot of reading on here about turning up the fuel on this truck some, well I have ground the fuel plate to a "100" profile and moved it towards the radiator and rotated the star wheel towards the engine some also I have the waste gate un hooked for now. I am not looking for smoke, but I would have guessed I would have some at take off and I have none. The trucks power went up some but not much. Am I missing something? I am going to have it timed and I have a boost/pyro/trans temp gauges that I am putting in tonight. The truck has 510,000 miles on it and is an auto, I know the milage is a little on the high side so I am wondering if that is most my issue. I can pull and test injectors here at the shop if I need to and I was going to put a fuel pressure gauge on it.
I am looking to make sure there is not something I need to fix, not a fan of the truck smoking a bunch.
Old Jan 17, 2012 | 03:21 PM
turbo2332's Avatar
4k govoner springs. check all your filters for gunk and proper fuel pressures. but the best mod you can do to you pump is gov springs.
Old Jan 18, 2012 | 11:55 AM
Mattman347's Avatar
Thanks for the info! I have looked at doing springs already, just the auto is probably not going to like it. I also thought about advancing the timing to 16* and see if that would help. The valves could use to be adjusted I'm sure also!
js77
Jun 14, 2015 08:40 PM
Nu2cummins
27
Jun 9, 2015 08:31 PM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
mtedrick4
Diesel Engine Conversions
Oct 13, 2014 09:25 PM
