rough running cummins
Old Jan 16, 2012 | 08:05 PM
94 dodge cummins's Avatar
Default rough running cummins
Hi i just got a 94 cummins, it hasnt been run for 5 years, we got it running but it runs good for awhile but then it acts like its not getting enough fuel and then it starts to smoke badly and wants to die. Could it be that its just gummed up from sitting so long or is there a bigger problem? thanks
Old Jan 16, 2012 | 08:13 PM
turbo2332's Avatar
how gross is the pre filter in the fuel heater?
Billy D's Avatar
I would replace the LP just in case fluids n filters.
Old Jan 16, 2012 | 09:37 PM
lunk's Avatar
ya lp possibly. and fass has dodge direct replacement pumps that flow three times more fuel with a 4 year warranty for about $300. my stock pump leaked where the wires where riveted to the pump and caused a hard start and stumble issue from air getting in
Old Jan 17, 2012 | 04:54 AM
captain_stabbin's Avatar
rig you up a mechanical fuel gauge an make sure its getting fuel before you start guessin an spending money on **** you dont need, could be a leaking injector
ofv something simple
Old Jan 17, 2012 | 10:51 AM
ok if i rig up that guage what psi should it be pushing the fuel at, and where is the fuel heater and prefilter located, so i can check those
Old Jan 17, 2012 | 03:15 PM
turbo2332's Avatar
fuel heater is under the injedction pump right beside the fuel lift pump. its easier to take it apart from under your truck
ssmith.77
Nov 25, 2018 06:56 AM
firefighteremt
Feb 2, 2015 01:59 PM
ssmith.77
Jan 11, 2015 02:03 PM
Fishy816
Jan 11, 2015 08:31 AM
bizurkhate
11
Nov 14, 2014 12:15 AM
