OIL LEAK
Old Jan 15, 2012 | 07:38 PM
silverbullet10's Avatar
Default OIL LEAK
Ok does anyone were the oil sensor is located on the motor of a 01, I noticed the oil leak and replaced the oil pan gasket but did not fix the problem if anyone has any info it would help alot. Thanks..
Old Jan 15, 2012 | 08:26 PM
RAW's Avatar
RAW
Where is the oil leak coming from? The vacuum pump gasket to timing cover is a popular spot for an oil leak.
Old Jan 16, 2012 | 08:00 AM
I am not sure but i will check those spots in the picture and get back to you thanks man
Old Mar 19, 2013 | 07:34 PM
sickboy29's Avatar
I'm actually in the middle of tearing mine apart to find leak too. No oil in front of sensor looks any other sorce of a leak around my fuel filter can ester area maybe anyone?
Old Mar 19, 2013 | 08:13 PM
BarryB's Avatar
take a look at the side cover gasket. lifter cover.
Old Mar 21, 2013 | 12:02 AM
blacksally's Avatar
i had a mastive oil leak from the turbo drain p\tube going into the block and you couldnt really tell i took the pipe out of block and it didnt have an o ring replaced no more leak
Old Mar 21, 2013 | 02:06 AM
sickboy29's Avatar
Hmmmm well tomorrow takin the rig to a friends shop and installing a huge box full of goodies!!!! It's like Christmas right now.... Ill let u guys know what it was its just wierd I'd doesn't seem to b comin from that cover where everyone's problem usually is
DIESEL BOMBERS KICKS ***!!
cummins Pride
Sep 28, 2015 12:11 PM
BKID
Jul 25, 2015 07:59 PM
Gomerpile79
Apr 9, 2015 03:45 PM
pro graphic solutions
Feb 10, 2015 03:48 PM
ash23k
Dec 30, 2014 08:31 PM
