what mods to do first
Old Jan 14, 2012 | 07:11 PM
94cumminsarmy's Avatar
Default what mods to do first
ok so i am purchasing my second cummins this one is a 24 valve the truck is stock except an air filter i want gauges but i herd that the fuel is to be upgraded too what should i do first just pullin a horse trailer and want to get best mileage possible
Old Jan 14, 2012 | 07:18 PM
battelbrothersdiesel's Avatar
majorty will say to replace the lift pump with a good aftermarket one. but since ure doing guages i would get a fuel pressure guage or the low psi light so u can keep tabs on what ure lift pump is doing. just my thoughts
Old Jan 14, 2012 | 07:50 PM
Billy D's Avatar
Raptor 100 and you won't have to drop the tank FP gauge fer sure
Old Jan 14, 2012 | 10:15 PM
globalwarmingcontributor's Avatar
An Airdog, Fass, or raptor fuel pump, throw on a mechanical fuel pressure gauge along with boost and EGT gauge..then get a programmer, Edge juice or comp. then get some good injectors. thats a good start!!
Old Jan 14, 2012 | 10:59 PM
luke46's Avatar
I tell everyone you need to see what's going on (gauges) and let that diesel breathe. (exhaust and air filter but you already have air) than go from there. You can get full 5" or 4" exhaust kits for 300 or less from the sponsors here just do a price request.
Old Jan 15, 2012 | 01:09 AM
bristoy's Avatar
like the others have said do the 4in exhaust & you said the air filter wasn't stock.does that mean it has an after market filter or a clod air intake, i.e. k&n,s&b ?if not you'll want to get a cold air system of some kind to help it breath better.make sure you get a fuel pressure gauge,NOT the low pressure light.i had the light & a brand new cummins lift pump.the lp went bad,took out my injection pump,the light never came on.i got one of the gauge pods that mounts on the steering column.it's easy to monitor there right below the speedo.enjoy your 24v,have fun.
Old Jan 15, 2012 | 01:32 AM
Gauges First and see what your lift pump is doing.
Luke
Old Jan 15, 2012 | 02:17 AM
RollinCoal99's Avatar
auto meter gauges, Airdog 100 or 150, Cold air intake, Exhaust, performance chip for better fuel mileage. that will get your diesel going good
Old Jan 15, 2012 | 03:42 AM
thanks guys and if i buy a programer wont that have all the gauges in it
Old Jan 15, 2012 | 03:56 AM
depends on what kind of programmer you get.. if you get an edge juice with attitude then yes you will have all you need on the screen, but if you go with edge comp, its just a chip on the fly, no screen.. its really up to you as to what way you wanna go. BTW, you in the army? im active right now, serving in south korea.
2004LB7
29
Feb 29, 2016 06:00 PM
Spaky6.0mudder
Aug 3, 2015 08:54 PM
lb7Garrett
Chevy/GMC Duramax 01-04 LB7
Feb 15, 2015 09:02 PM
dieselpowa
Jan 26, 2015 03:02 PM
rtbcoop
Dec 30, 2014 02:13 AM
