Help with 99 clutch system!
Old Jan 14, 2012 | 12:23 PM
Devon527's Avatar
Default Help with 99 clutch system!
So I just replaced my clutch in my 99 cummins, but while installing everything my buddy forgot to put the push rod in the slave cylinder and lost all pressure in my clutch pedal... trying to get it to work without buying a whole new system, what can I do to make it work? Really want to get the truck running... Thanks ahead of time
Want to get my truck fixed today so if anyone can help it would be much appreciated
Old Jan 14, 2012 | 11:36 PM
Cody Cummins's Avatar
Mopar1973Man's Dodge Cummins Articles - Hydraulic Clutch Master And Slave Cylinders Replacement
Follow that, it will show you how to bleed everything had to do mine last weekend!
Old Jan 15, 2012 | 07:29 PM
Devon527's Avatar
AWESOME! if you can recall how long did it take you? And how much money did it take?
Old Feb 1, 2012 | 05:58 PM
Devon527's Avatar
So I replaced the slave cylinder just like it said to do and primed it till full, but my clutch engages right on the floor... and disengages like an inch off the floor, what can I do to fix this?
Old Feb 1, 2012 | 06:30 PM
crazycooter's Avatar
I cheated on mine and used a vacuum pump to collapse the bladder in my cap before I screwed it on, and got rid of that problem, and she has been fine for several months now.
Old Feb 3, 2012 | 01:26 AM
Devon527's Avatar
How exactly do you do that??
Old Feb 3, 2012 | 09:09 PM
screw the lid on all the way, then use the hole in the lid, suck all the air out of the bladder with the vacuum pump, crack the lid to let air into the res, and screw the lid back on. not sayin' it will work, but it did for me.
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Turbo67
Jul 25, 2015 02:26 PM
Wyocumins
Oct 19, 2014 09:34 PM
