Idles a little rougher when cold now
Old Jan 14, 2012 | 12:21 AM
sweetv8s10's Avatar
Default Idles a little rougher when cold now
For about the first five minutes when its cold outside its idles rough and then it clears up and runs just fine it didnt use to do this I was thinking maybe an injector but not for sure anyone else have any ideas?
Old Jan 14, 2012 | 10:05 AM
johnnyreb's Avatar
are youadding any winter fuel treatment to it? the diesel now days seems to be like gas, IT SUCKS!
Old Jan 14, 2012 | 01:00 PM
cougar's Avatar
Could also be your KSB doing its thing. Way to find out is to unplug it.
Old Jan 14, 2012 | 01:58 PM
tower_ofpower's Avatar
Sounds like the KSB to me, nothing to be concerned about. If it bugs you too much, simply putting a toggle switch to hot wire the KSB once the truck is running has no adverse affect on anything.
Old Jan 14, 2012 | 02:07 PM
NadirPoint's Avatar
Cold idling is very bad your engine. You have incomplete combustion washing down the rings and cylinder walls causing excessive wear. If you must cold idle it that long increase the rpm up to 1100 or so.
Old Jan 14, 2012 | 09:12 PM
sweetv8s10's Avatar
I already have my ksb on a toggle switch but should I leave it on for a little bit when its cold or only when I first start it then shut it off?And Nadir are u saying I shouldnt let my truck warm up in the morning?
Old Jan 15, 2012 | 09:07 AM
NadirPoint's Avatar
Originally Posted by sweetv8s10
...I shouldnt let my truck warm up in the morning?
Not at the normal 7-800rpm level - bad idea. That's why the newer electronically controlled common rail engines automatically push cold idle to 1000rpm when the temp sensors detect ambient temp below a certain level. If you do not have any way to do that, than then the best approach to cold starts is to sit there with your foot on the throttle holding it above 1000rpm and/or drive away slowly soon as it smooths out within the first minute or so.
Old Jan 15, 2012 | 10:48 AM
sweetv8s10's Avatar
What about my ksb should I leave it on for a little bit?
Old Jan 15, 2012 | 11:13 AM
NadirPoint's Avatar
Yes, the advanced timing helps cold combustion. That's what it's there for - it's a primitive pollution control device to reduce cold smoke after start-up.
Mike0885
May 27, 2015 12:07 PM
1997silverado
Jan 23, 2015 05:06 PM
iMixDiesel&Gas
Dec 27, 2014 09:57 PM
custom7.3
Nov 24, 2014 05:16 PM
12vbomber
Nov 4, 2014 10:04 PM
