Need Help! 99 3500 Not Charging
Old Jan 14, 2012 | 12:02 AM
txbowhunter28's Avatar
Default Need Help! 99 3500 Not Charging
I've got a 99 3500 that I've had some charging issues with....mainly the plug on the back of the alternator not connecting well. I decided to remove the burnt up plug and replace it with some female spade type connectors. It had quit charging all together before removing the plug, I assumed the plug was bad. Now after replacing the terminals it still does not charge. I got a new alternator, installed it, still no luck. Can anyone point me in the direction as to how I should diagnose this? What can I check? Should I get any voltage from the 2 small wires on the back? I'm clueless at this point. Is there a fuseable link anywhere that could have blown? Any help would be greatly appreciated!
Old Jan 14, 2012 | 12:55 AM
01quadcab's Avatar
the computer controls charging so you might need a new one
Old Jan 14, 2012 | 06:34 AM
Rooster24v's Avatar
Check your fusable link on the drivers side wheel well under the hood inside the fusebox. IF that is popped you wont charge. take a peek at that before you do anything else.
Old Jan 14, 2012 | 12:03 PM
Are you talking about the one labeled alternator fuse? Already checked that, its good.
Old Jan 14, 2012 | 06:29 PM
Rooster24v's Avatar
Its located in the fuse box atop of the drivers side wheel well. Its right on the side where the red and black battery wires come into the box.
Old Jan 14, 2012 | 06:31 PM
Yep, checked that, its good.
Old Jan 14, 2012 | 06:37 PM
Rooster24v's Avatar
well then im stumped....
Old Jan 14, 2012 | 06:40 PM
I've narrowed it down to the green wire at the back of the alternator. Everything else is right. Still trying to figure out exactly what it does, I do know by the wiring diagrams, that it goes to the PCM.
Old Jan 16, 2012 | 06:57 AM
tworks's Avatar
The green wire is your regulator wire...regulated to ground through the pcm. The blue wire should be key on power.
Old Jan 16, 2012 | 10:30 AM
puffsmokeonya's Avatar
mine did the same thing. the ecm on the fire wall fixed it. i got a new one. its not too expensive from a salvage yard. just try to get a match on what your truck is.
