turning barrels... good or bad?
Old Jan 13, 2012 | 12:49 PM
M-Schuler's Avatar
Default turning barrels... good or bad?
i hear and read alot about turning the barrels on a p-pump.. and im tryin to figure out what exactly it does and weither its good or not? and if its worth doing how is it done..
Old Jan 13, 2012 | 07:38 PM
gwhammy's Avatar
Most have good luck with it, some don't. Around 30 to 50 horsepower. I've done two pumps and getting ready to do one tomorrow.
Old Jan 13, 2012 | 09:54 PM
M-Schuler's Avatar
people say it throws the rack off balance..i want to do it but im just worried that could damage my pump..
Old Jan 13, 2012 | 10:56 PM
Heavyhaul07's Avatar
What do u meen buy turning the barrels? Never heard of it thanx
Old Jan 14, 2012 | 12:36 AM
IHdude's Avatar
i would like to know more on this too
Old Jan 14, 2012 | 06:20 AM
gwhammy's Avatar
Do a search, this has been gone over alot. If you are scared or can't afford to have the pump worked on if it screws up don't do it.
I talked to a good pump guy about this his take is most pumps are off more than people think. He said even a pump he balances will be off in a year from wear. My 160 pump was smoother with the barrels turned than it was stock.
It's a nice little horsepower boost but not for everyone. It's a simple 20 minute job if done right, a days work and 2 to 400 dollars to fix what you screwed up if done wrong. I'm not trying to discourage anyone just telling it like it is.
Old Jan 14, 2012 | 11:55 AM
M-Schuler's Avatar
alright.. im probably not gona do it just cause i dont trust myself no to mess up anything in the pump.. and that $2-400 possible repair is something i cant do.. haha.. but thanks for the info man
Old Jan 14, 2012 | 01:07 PM
turbo2332's Avatar
i still dont know what there is to repair? there is nothing to break in the process unless you go crazy with the punch and hammer and crack a holder???
Old Jan 14, 2012 | 02:10 PM
M-Schuler's Avatar
im stuck in the middle about turnin them.. also i pulled a set of stock injectors apart.. is there anything i can do with them myself to make em better or no? just figured id ask since i have em apart..
Old Jan 16, 2012 | 06:58 AM
gwhammy's Avatar
The one that was on here I think broke the gasket between the barrel and pump is what he thought happened. I don't see it happening very often but if it happens it's going to cost. I'm not scared to do it but I am able to except the worse case senerio.
