hey guys
i have a 96 cummins 3500 ext cab 2wd with 311000k on it, i was wondering if a motor with this milage will support 500hp possibly? i wanna make it a tow rig but idk if she will pop under that power
Shouldn't pay more than 440-460 shipped if gotten from a vendor here on the site. Those studs are direct fit, no additional machining or bottom tapping of the block (as long as the rocker pedestals are machined so the valve covers fit properly) the $1000 "custom aged" head studs I believe are a larger diameter that requires re-tapping the block etc etc. those studs I wouldn't believe are needed unless you're able to push 80ish psi or better. The $400 dollar studs with out fire ring are reliable to 50-60 psi or so. It's really kinda here-say no one can garuntee when it'll fail just that they typically fail around such pressures.
Go to the armory and request a price on a set of ARP's a vendor should be able hook you up with a price better than anything you're seeing online. I know BBD sells a set of pre-machined rocker pedestals that'll make your install a breeze.
