01 2500 not starting
Old Jan 12, 2012 | 03:45 PM
gfmccutc77's Avatar
Default 01 2500 not starting
My 01 2500 5.9l cummins was starting really hard, finally one morning it just wouldn't start. I replaced the lift pump, fuel filter, and injector pump. It still won't start and it's not throwing any codes. Any suggestions?????
Old Jan 12, 2012 | 06:36 PM
aguilar_15's Avatar
What exactly is it doing? Any clicking, grinding... Anything? Have you checked your starter? Batteries? Details man, details!
BTW
Old Jan 12, 2012 | 06:47 PM
gfmccutc77's Avatar
All the thing is doing is cranking over. I'm thinking it could be a sensor, but where to start?? I'm not sure what all controls the cummins starting, which makes things harder.
Old Jan 12, 2012 | 07:10 PM
empty wallet's Avatar
New oem lift pump? on block? can you hear pump priming if you bump starter? Have you cracked injector lines to bleed air out?
Old Jan 12, 2012 | 07:35 PM
gfmccutc77's Avatar
Ok here we go...truck wouldn't start one day, so I replaced the injector pump. Read a write up about the vp44 and invested in a new lift pump n fuel filter. I bleed the filter housing, then the injector lines that I can get to. The lift pump is cycling properlyy far as I can tell.
Daniel Finney
Oct 22, 2019 01:58 PM
hurriedcoyte
Jun 19, 2015 06:26 AM
DirtyDiesel58
Jun 7, 2015 11:50 PM
InheritedDiesel
Apr 12, 2015 04:35 AM
Dec 29, 2014 10:20 AM
