Project 12 Valve Cummins
Old Jan 12, 2012 | 11:00 AM
M-Schuler's Avatar
Default Project 12 Valve Cummins
So I got a project motor for my truck.. I wana build it up to make some serious power.. Ya know the kind to make your friends scared of your truck! Its out of a 95 dodge that had a 5spd so it has a 180 pump.. Any ideas?
Old Jan 12, 2012 | 02:06 PM
turbo2332's Avatar
how far is far? and what are you going to use the truck for other than scaring your friends? how much cash are you looking to spend??? and i believe you have a 175 pump to my knowledge the 180's came on the later automatics. 96-98
Old Jan 12, 2012 | 05:17 PM
M-Schuler's Avatar
ok yes i looked it is a 175 pump.. ive been pricing stuff out and from what needs to be fixed over time when i build it up im probably gona be close to 8K..
Old Jan 12, 2012 | 05:24 PM
turbo2332's Avatar
what are your plans with the truck? what power are you wanting to get to? is your tranny already built or is that part of the 8K?
Old Jan 12, 2012 | 05:29 PM
M-Schuler's Avatar
i wana make this truck a good street truck but good enough to kick some *** on the track and in the dirt.. i want around 575-650 hp and 1000+ ft lbs
Old Jan 12, 2012 | 05:47 PM
cummins3500's Avatar
Default hey
do u have an auto or manual trans?
once your trans is out of the way getting power out of he engine isnt hard ur gonna need head studs, head gasket injection pump work as in #100 fuel plate or run no plate i do that in my 94 2500, dv's injectors rack plug, 4k springs advance timing, afc tuning, hd valves and my fav the turbo, im thinking of compound on mine but a single can get u too 600hp+
Last edited by cummins3500; Jan 12, 2012 at 05:47 PM. Reason: Automerged Doublepost
Old Jan 12, 2012 | 05:56 PM
turbo2332's Avatar
head work (ported,oringed, or fireringed)
a good flowing pump (with similar goodies listed above)
def recommend twins for over 500 hp lag will be a problem with a single
head studs
prolly around a 5x.016 injector with twins
an upgraded fuel system
possible a cam
all the gauges if you dont already have them in the truck
these engines are close to double between HP and TQ
Old Jan 12, 2012 | 06:53 PM
M-Schuler's Avatar
i got the nv4500 in mine.. i know about the head studs and all the gaskets.. ive been looking into industrial injections p-pumps and injectors.. also their complete street/race head with 150lb exhaust valves and billet roller rockers.. also looked at a ats twin turbo set up.. a cam would be nice.. what fuel systems would you recomend? I have a guage pillar with etg and boost.. also probably gona do a dual disc clutch from southbend..
Old Jan 12, 2012 | 08:09 PM
turbo2332's Avatar
5th gear wont stay together long with 600 ponies. as far as fuel something that will supply enough to the injection pump. call FASS or somebody up and explain what your getting into. go one size biggerthan what you need so if plans change you can go bigger with out redoing. and you dont need roller rockers to make 600HP mark that off your list unless you cant stand not to have them.
Old Jan 13, 2012 | 12:57 PM
M-Schuler's Avatar
alright.. well im gona see where i go with this motor.. i listed about 90% of the parts on craigslist.. cause im just gona rebuild with new and better parts and see where i land with $$ and hp/tq
