Irradic Fuel Pressie
Old Jan 11, 2012 | 09:48 PM
colinheitshusen's Avatar
Default Irradic Fuel Pressie
So im drivin home tonight and all is good, and all of a sudden my fuel pressure guage starts jumping around like crazy. jumps from 10psi to 30 psi irradicly. the truck has the "grease gun" style sending unit with a snubber valve in it. I didnt install it, but bought it like that. if anyone could shed some light itd be appreciated
Also not sure if it helps but its a gloshift guage.
Thanks,
Colin
Old Jan 11, 2012 | 10:24 PM
Whit's Avatar
Site Mascot
whats the pump
Old Jan 11, 2012 | 10:35 PM
out of tank. vp
Old Jan 12, 2012 | 08:03 PM
cerickson's Avatar
Could be the guage. I had an isspro fuel guage that bounced around and had a rattle to it. I replaced it and it cleared up. Local diesel shop said it was probably a defective guage. They said it was probably the snubber. I replaced it and the guage at the same time. Problem solved.
Old Jan 12, 2012 | 10:02 PM
It must be my snubber valve, cause now it just says its pegged at 30. I'll have to tear into it tomorrow and see
Old Jan 13, 2012 | 12:03 AM
wyodiesel92's Avatar
Bad sending unit for the gauge. Went through 3 on my old truck in 3 months with a snubber. Glow shifts fuel pressure sending units seem to be junk for us. My buddies ps just had his go bad after 3 months. But id replace the gauge with a quality one and use a needle valve as a snubber
Old Jan 13, 2012 | 10:26 AM
Ive heard the Gloshifts were kind of sucky gauges. But again i didnt put them in. Ill just have to try a new snubber first
Old Jan 13, 2012 | 12:56 PM
Nutty Jeeps's Avatar
if the snubber went bad more than likely the sending unit on the gauge is bad now to. Happened to mine when who installed the gauge failed to even put a snubber on
Old Aug 18, 2013 | 11:40 AM
oneil250's Avatar
I went through 3 Glowshit FP sensors (with snubber valve installed). Finally on the 4th one i made up a foot long hose and ran it off the banjo fitting on my VP44. Has been good for about 4 months now.
Old Aug 19, 2013 | 01:22 PM
jigabop's Avatar
snubbers are junk. Hard to find one worth a damn.
you are better off to use a needle valve instead and just barely open it a crack...
it should cause the gauge to sweep slowly and take a couple seconds to read full pressure if it is set properly.
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
