STARTING ISSUE 2003 cummins
Old Jan 11, 2012 | 05:08 PM
CMH10's Avatar
Default STARTING ISSUE 2003 cummins
Hi guys any help or direction in where the problem might be would be appreciated, what i have going on is my truck will fire once and then gets no fuel.i let it sit over night and the next day it started.no light came on and no codes show on the dash.my friend plugged his code reader in and no codes appear except a start/run theft code or something of that nature.it has started 8-10 times since no problem and today it bothered again i tried it about 20 times and i finally got it started with feathering the throttle.could this be a sensor?cp3 pump?any ideas?
i do have a smarty on level 9 plus timing as well as a quadzilla exhilerattor 6 postion chip that is in the off position FASS fuel system that is running
Old Jan 11, 2012 | 05:55 PM
wildbill's Avatar
Your plv is leaking or a high pressure fuel leak. It's on the fuel rail, next to the rail sensor. Remove the banjo bolt and check. If fuel is present, it's shot, if not, you got a high pressure fuel leak or an injector that's bad.
Old Jan 11, 2012 | 06:15 PM
MillerBoyzDiesel's Avatar
i would be looking into the theft code, see if its setting each time truck wont start.
Old Jan 11, 2012 | 06:20 PM
K80's Avatar
K80
Is your fuel gelled? Stupid question, just throwin it out there.
Old Jan 11, 2012 | 06:29 PM
wildbill's Avatar
But he also mentioned he has to feather the throttle pedal.
Old Jan 11, 2012 | 06:31 PM
CMH10's Avatar
my fuel shouldnt be gelled its about 40 degrees outside and this problem just randomely started.the truck usually fires and is running in 2 seconds.on the dash when i press the trip reset and turn the key for those codes 23 comes up when i cycle the key 3 times no codes show so im not sure how to go about the theft.
Old Jan 11, 2012 | 06:40 PM
youd probly have to use a scan tool. if you can get access to one id watch fuel rail press. while cranking and make sure its building to 5k when your problem is occuring.
Old Jan 12, 2012 | 08:19 AM
K80's Avatar
K80
Ok. This ^^is what threw me off. Get something that will check RP and start there.
Old Jan 14, 2012 | 01:44 PM
*dixistar*'s Avatar
My quadzilla was making my truck do that it blew the pressure relief valve and then it shorted out for. No reason. May not be ur prob but def something to look at
Fuel is. Always going to be ther its part of the return, the only good way to test the pressure relief valve is to run a rail pressure ramp test it has to hold at least 28k at 1800 rpm
Last edited by *dixistar*; Jan 14, 2012 at 01:44 PM. Reason: Automerged Doublepost
JoeyMiR
9
Feb 3, 2018 10:05 PM
dskewes14
Sep 14, 2015 09:19 AM
hurriedcoyte
Jun 19, 2015 06:26 AM
Oct 28, 2014 08:10 AM
dieseldude03
For Sale
Oct 2, 2014 07:53 AM
