Ground Activated
Does anyone know if the lights on the second gen trucks are ground activated? I need to install daytime running lights and I need to confirm this before I purchase the DRL module.
Thanks,
Thanks,
Response appreciated.
The pull out type headlamp switches are switched power, We have a 98 12valve up here and its ground controlled. 98 might go either way. Id say if you have pull out type switch its switched power and if you have the flip switch the headlamps are ground controlled.
Much appreciated.
i have a '96 with drls and the modual is on the inside of the drivers fender around the brake booster i wonder if they might have wired them all for drls for the sake of simplicity. is there an empty plug in that area? mine is a canadian truck built in mexico if that makes any difference
there is an empty plug with flat pins in mine around there too. i know the drl plug has round pins and some are larger then others. im guessing there are 8 pins but im not sure (nowhere near truck right now)
