VE Pump Idle Adjustment Tricks?
Old Jan 10, 2012 | 05:52 PM
Cummins12Club's Avatar
Default VE Pump Idle Adjustment Tricks?
does anyone have any suggestions or tricks on turning my idle on my VE pump down, any info is appreciated, thanks
Old Jan 10, 2012 | 08:26 PM
tower_ofpower's Avatar
Back your full fuel screw out or get a dremel and grind a wee bit off
Old Jan 10, 2012 | 09:10 PM
sweetv8s10's Avatar
Just use a small chissel to break the nut lose then it should turn pretty easy.
Old Jan 10, 2012 | 11:19 PM
Rusty89Cummins's Avatar
could probly loosen up the inj pump and turn away from the head to get to the jam nut easier and idle rod. if nothin will move then just cut the rod back to where you need it and turn the fuel skrew in more if you need to bring the idle back up.
Old Jan 11, 2012 | 09:05 AM
ricet07's Avatar
On the right day with a little bit of patience you can fish a 12" extension with a swivel and flat apex behind the pump to get it turned.
Old Jan 11, 2012 | 10:48 AM
sootnsmoke's Avatar
I was looking at this the other day for easier access to the idle adjustment:
Dodge Diesel - Diesel Truck Resource Forums - View Single Post - Fast Idle advice for a noob
Old Jan 13, 2012 | 12:33 PM
wisconative's Avatar
Default Thanks again
Made the wrench last night -- When I go to adjust it do I turn it clock wise or counter clockwise to bring up the idle? (I am asking like I am sitting in the drivers seat perspective)?
Old Jan 13, 2012 | 03:21 PM
Clockwise
Old Jan 14, 2012 | 07:47 AM
Thanks for the help, the chisel worked extreamly well and easy
Old Jan 16, 2012 | 09:11 PM
I found wrench to be a waste of time -- I couldn't get it to purchase -- reheated it a couple of times to try different angles.
Some pb blaster and One light tap with a chisel -- done.
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
HardLuck
Jun 24, 2015 08:04 AM
ctjkelley
Jun 3, 2015 06:01 AM
Gm3500
May 7, 2015 11:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
