Torque Converter Lock/Unlock / OD Hunting Issue!!
Old Jan 9, 2012 | 08:14 PM
12vCummins94's Avatar
Default Torque Converter Lock/Unlock / OD Hunting Issue!!
I had this problem a while ago, took my TPS out cleaned it thoroughly, and didnt have the problem again for 2 months. I recently (in the last month) started having the SAME issue again. I recently replaced the alternator, checked batteries, re-grounded all 17 grounds, and installed the BD APPS Noise Isolator. I also replaced the TPS only finding out that it was still doing the same thing, so i returned the new TPS and put in the old one...
Still having the same issues. Any ideas guys?? Its turning into a money pit trying to figure out whats causing it
P.S. There is some play with the bell crank which connects to TPS...so maybe its the bushings?
Old Jan 9, 2012 | 09:35 PM
Torkjunky's Avatar
Did you check your voltage at idel and then trough the throttle stroke?
Might try the POT in place of the TPS. I have not tried it but some folks say it is the way to go.
rstrange1996
Sep 22, 2015 01:25 PM
alysiamc
Jun 19, 2015 02:03 PM
cumminsbred01
Feb 17, 2015 12:26 PM
Jgloveracob
For Sale
Dec 7, 2014 10:47 AM
Tmaxxrox97
10
Nov 10, 2014 10:37 PM
