Adjusting the factory steering box
Old Jan 7, 2012 | 01:38 PM
wellmi's Avatar
Default Adjusting the factory steering box
Hey i heard you can adjust the steering linkage inside the box making your steering tighter or looser, but i couldnt figure it out by looking at it. I would like to replace it with a new steering box but i dont have the money right now, so that will have to wait. Thanks
Old Jan 7, 2012 | 01:44 PM
tjwc1's Avatar
On the top near the center, youll find a jamnut and a allen head screw. loosen the nut and turn in the screw. try the feeling and readjust.
Will only bandaid the problems for a while.
make sure when you replace it to go to a close ration box way nicer
Old Jan 7, 2012 | 02:47 PM
Rodeocummins's Avatar
I adjusted that jam nut, Allen head an it worked. Then I greased my front end an it also helped.
Old Jan 7, 2012 | 07:25 PM
wellmi's Avatar
thanks guys i do need to regrease my front end i doubt its been done since it rolled off the factory floor
Old Jan 7, 2012 | 08:13 PM
tower_ofpower's Avatar
Gotta be careful, too tight and your steering can become rather touchy. The sector shaft is supposed to be a variable rate design and running too tight kind of takes away the "gradual adjustment" designed for highway speed corrections
Boostaddiction
May 4, 2015 06:28 AM
BubbaDT55
Apr 12, 2015 10:47 PM
sweetv8s10
Oct 7, 2014 09:47 PM
